ECU - 325 Chip questions
Posted: Mon Apr 18, 2011 2:35 pm
by DrGonzoPOW
The ECU i have for my coversion is from a 320 E30 but I was also given a 325 chip by Jimmi a good while back. Are the 320 and 325 ECU's the same other than the chip inside ??
And if i were to get a performance chip off the internets what's the best one to go for ?? Cheers
Re: ECU - 325 Chip questions
Posted: Mon Apr 18, 2011 3:06 pm
by arshad76
Hiya Gonzo, there are quite a few chips on the market. Some are supposed to be good, some do more damage then good. You might want to do a search on E30 Zone, as there are a few number there. I actually have a chip by Ant from -tech off there, but in two minds on fitting it or not.
Posted: Mon Apr 18, 2011 3:11 pm
by Mobster
If its the original 325i chip, then that is the one you want to be using unless you want to get a Alpina 2.7 chip from ebay. About £40
Posted: Mon Apr 18, 2011 3:18 pm
by DrGonzoPOW
Far as i know its an original 325 chip and i have an original 320 ecu, is there no problem putting this chip in this ecu ??
Do the Alpina ones add 10hp or so ? Ta
Posted: Mon Apr 18, 2011 3:24 pm
by Mobster
they say the Alpinas ones do but i'm not convinced myself. I have an original 2.7 chip from a c2 but i didnt put mine on the rolling road before i put the chip in so god knows. As for the 325i chip, i am pretty sure you can but check with Murran or Jason.
Posted: Mon Apr 18, 2011 3:49 pm
by DrGonzoPOW
Think i remember Murran saying you could but wanted to double check as i dont wanna break owt !
Posted: Mon Apr 18, 2011 5:22 pm
by e21-Mark
2.7 chip is no use on a 2.5. I learnt the hard way having been sold a supposed 2.5 chip that turned out to be one of Ants (A-tech) 2.7 maps. As a result it over fueled at several points and ran way too rich. *note to self buyer beware* Either Ant or Speedtouch on e30zone can supply the correct one. IMO the best one is the hi-torque/fast road version.
