NOISY DIFF? WHICH OIL?
Posted: Thu Apr 28, 2011 11:38 am
by Morris
Hi,
My mechanic thinks that the whining noise on my 316 auto is from the diff.
He wants to change the oil and add some diff additive to see if that cures the problem.
what oil is used in the diff? 80/90 gear oil / atf ??
Re: NOISY DIFF? WHICH OIL?
Posted: Thu Apr 28, 2011 12:48 pm
Did u ever check out that website called bmwe21.net? Some useful info there including all factory specs like on this page:
http://www.bmwe21.net/?page_id=282
diff oil SAE 90 change quantity 0.95 litres
Posted: Thu Apr 28, 2011 6:02 pm
by Kogando
Most likely your pineonbearing is worn out. You can use 75w90.
Posted: Thu Apr 28, 2011 10:57 pm
by --ALPINA--
dude if it s whining then changing the oil aint gonna eliminate it unless you pack it full of sawdust and even IF!! change the diff its damaged or repair it.... cheaper to change.
J
Posted: Fri Apr 29, 2011 9:32 pm
by murran
mines noisy. needs to get worse before i'll do anything about it. might change the oil on it at some point.
bung some hypoid 75w90 in it, if that doesnt quieten it down then its knackard.
