Page 1 of 2
Bilstein Part Numbers
Posted: Tue Oct 11, 2011 5:11 pm
by Kpeters
Hi guys I wanted to see if you can help me out finding which Bilsteins will fit my 320/6 1981.
Lots of suppliers in the US will try to sell you 320i stuff but looks like they won't fit according to BMW's ETK.
If anyone of you can give me the Bilstein part numbers for the correct ones for a 320/6 I'd be grateful!
Also I've no idea if I have sport suspension from factory or not my guess would be no.
thanks!
Re: Bilstein Part Numbers
Posted: Tue Oct 11, 2011 8:21 pm
by Peter V.
Posted: Tue Oct 11, 2011 8:47 pm
by Kpeters
Thanks but for some reason the E21 doesn't appear at all....
It's a real pain and I also tried Boge but Boge says 320i and 320/6 are the same which contradicts what BMW says im so confused!
And I work at this feeling a bit ashamed of myself right now hahha.
Posted: Tue Oct 11, 2011 8:53 pm
by Peter V.
The link is from the E21.
When you go to the online catalogue choose BMW. Then scroll towards the bottomlines and the E21 and even the BMW 02-series are there.
Posted: Tue Oct 11, 2011 9:04 pm
AFAIK the P30-0121 B6 fronts fit all E21's except the 323i but you need a different nut on top than with any other brand of shocks. Available from B. as well.
Rears are all the same.
So this should all fit:
http://www.pelicanparts.com/BMW/catalog ... hk_pg1.htm
http://www.turnermotorsport.com/BMW-E21 ... hocks.aspx
http://www.europerformance.co.uk/pages/ ... category=1
If anyone thinks differently speak up now or forever hold your peace
Posted: Tue Oct 11, 2011 9:25 pm
by Kpeters
Thanks just gotta figure out the German now! And I know my name is German but my grandfather didn't stick around long enough to teach me how to talk german!
*EDIT* Found a way to make it english! Thanks a lot I willo play with this for a while!
Posted: Tue Oct 11, 2011 9:26 pm
by Kpeters
Hi Jeroen thanks a lot so let me see if I get this straight.
320i USA= Will fit only the rears.
And for the front I need the P30-0121 B6 but with a nut provided by billstein?
Right?
Posted: Tue Oct 11, 2011 10:54 pm
Jeroen wrote:AFAIK the P30-0121 B6 fronts fit all E21's except the 323i ...
Let's just wait a day and see if someone else thinks differently but I think this is the story
Posted: Tue Oct 11, 2011 11:05 pm
by Kpeters
Ok I appreciate it! I had a lot of guys saying the 4 cyl front shocks are different than 6 cyl even the struts too.
Posted: Tue Oct 11, 2011 11:08 pm
by Peter V.
That's strange. I had it in english when i copied the link. I know you are not a german. Most important is that you know which Bilstein you need now.
Posted: Tue Oct 11, 2011 11:34 pm
Anyway, the official website lists the following part nos for the 320/6 (that can also be found on the other websites posted above):
B6 gas
Front 34-001219 aka P30-0121
Rear 24-006125 aka B46-0612
B6 gas with sports suspension
Front 34-002230 aka P36-0223
Rear 24-006125 aka B46-0612 (same as regular B6 gas)
The rear shocks are both the regular dampers that are 2-way heigth adjustable, the earlier sports units with 4 or 5-way heigth adjustment are NLA
There's also the regular and cheaper B4 gas dampers but if you're into some spirited driving I can recommend B6's
Posted: Tue Oct 11, 2011 11:54 pm
by Kpeters
Great I appreciate it! Sorry if my attention span has been bad. Hectic day.
Posted: Sat Nov 19, 2011 12:03 am
by 3771489
Jeroen wrote:Jeroen wrote:AFAIK the P30-0121 B6 fronts fit all E21's except the 323i ...
320/6 with sport suspension (M-technic) and for example 315 tropical-version have same front struts as 323i. So,not all.
Posted: Sat Nov 19, 2011 12:44 am
by Kpeters
How can you identify the sports suspension?
Posted: Mon Nov 21, 2011 5:43 am
by redline
3771489 wrote:Jeroen wrote:Jeroen wrote:AFAIK the P30-0121 B6 fronts fit all E21's except the 323i ...
You are both correct!!!! There are actually 2 sports bils for the E21. One for 315 to 320/6 and one for the 320/6 & 323 which uses the "323" stut housing. I know because i have already gone through this route. My 320/6 is currently on the M-Tech suspension ment for the 323. I also have the complete set of the Bils sport lowering kit for the 315-320/6. Was intending to fit that to another E21 but that fell through. So if anyone is interested in a pair of "new old" front bils sports dampers let me know. I will be keen to let it go. You have to factor in the postage from singapore to where you are though.
Cheers
