M42 conversion
Posted: Wed Jan 11, 2012 11:47 pm
Hi guys,
I'm looking to carry out a M42 conversion on my 1983 316. Whilst I appreciate that this has been covered a number of times before, I cannot find answers to a couple of specifics relative to the donor car I am considering using (1995 318is E36).
-All of the conversions I've seen have used an E30 gearbox and engine.I presume that the engine/gearbox do not have any differences between those used in the E36 other than the sump?
-As far as I am aware, all E36s have an immobiliser built into the ECU. Is there any procedure whereby this can be removed/bypassed?
-I've read a number of articles whereby the owners have intended to mount a fabricated rotor on the diff in order to power the E36 speedo mounted into the E21 binnacle. However, I've never seen the finished article; is the consensus that a gearbox with a speedo drive from an E21 (6 cylinder?) be a better option? Would my exisiting gearbox from my M10 suffice?
The donor I am planning on using is very cheap (£250) however, if the difficulty of modifying the E36 parts to fit would be too great, would it be recommended to try and source a doggy old E30 iS?
If there are any good threads that anybody has seen/ used on their own project, I would appreciate it if you could point me in the right direction.
Thanks for any help you can provide and please accept my apologies if these topics have been covered before; I have searched the forum for hours for previous threads, but never found anything entirely relevant to this particular project.
Cheers, Jason
Cheers, Jason
