Hgh beam wire
Posted: Sun Jan 22, 2012 6:16 am
Hi there all, still working on things, promise some photos this week.
Have installed a H4 conversion kit, which included two H3 100 watt highs, which I have connected through a relay and switch.
To trigger the relay need a postive feed from the dip switch, so tapped into the white wire on number 50 plug connector.
All should work, but the white wire carries power when dip switch is undipped, loses power when highs are selected.
So a bit stumped. Could connect up to the high wire up at the H4 lights to trip the relay, but wanted to keep things simple under the dash.
Any thoughts would be welcome
Chris
Chris
