Brake Discs
Posted: Mon Feb 13, 2012 11:02 pm
by cdavie2002
Not sure iv got the name right, but whats the benefit of floating bell brake discs as opposed to a one piece brake disc?
Does anyone use them?
Re: Brake Discs
Posted: Mon Feb 13, 2012 11:16 pm
by Jason_323i
The benefit is lost weight, and ease of custom brake setups. It is easier to make a custom bell to suit a standard bolt disk than make a 1 part disk. Also a 300m bolt disk is £50 cheaper than typical 1 part disk, but for motor sport you are recommend to replace the alloy bell every season.
There are to types of alloy disk bell combo's float and non floating. This is to do with the way they are bolted together and is to mange the different rate of expansion between alloy and steel.
I use them and have a set for sale
http://www.bmwe21.net/forum/viewtopic.php?f=5&t=17086
Jason
Re: Brake Discs
Posted: Tue Feb 14, 2012 7:25 am
by cdavie2002
Iv got new wilwood calipers already, 120-8729. They look impressive, propably overkill for mine for just normal road use.
Can you buy them in the size that would replace my rotors, 255 x 22. ?
