That was a close moment
AusChris
Post by AusChris »
As some might know, car has had most of the front end steering and suspension replaced, by yours truly. And, the ride has been sensational, until Saturday...
I was going to the local shop - about 4k away. As I went around a round about, the car twitched when it shouldn't. When I straigtened up, the steering wheel was no longer centred and the car want to pull left.
I was near shop, so parked and got my things. Had a look under and noticed the passenger front wheel was further forward than it ought to be. I figured I needed to jack up and suspected the steering rack had moved. So drove home.
This is what I found:
Shit. So close to disaster. Took me an hour to line everything up again and push the bolt through, torquing it properly with the right 19mm nut and washer. I can only conclude that I didn't tighten correctly, or (shame), left the nut off altogether. This was three weeks ago, have driven down coast and so on....
Regards to all - Chris
Re: That was a close moment
Brrrr lucky escape mate!
DrGonzoPOW
Post by DrGonzoPOW »
Woah, was your arm just about to fall out!?
Wakefield Hellfire
garyw51
Post by garyw51 »
Lucky catch Chris. Unfortunately I have seen it happen before - luckily not to me.
gary[color=#BF0000][/color]
e21 Alpina (Aust) 82
e21 Baur 82
79 323 auto
80 635
80 e12 M535
When you have the possibility you put the bolt from the other side in. She can not escape then because of the steeringarm.
DrGonzoPOW
i put them in the other way around when i did the suspension cuz it was a bitch to get in otherwise. Its the first thing ill be checking next time i go out in it!!
Wakefield Hellfire
AusChris
Post by AusChris »
Peter V. wrote:When you have the possibility you put the bolt from the other side in. She can not escape then because of the steeringarm.
Agree Peter, it was precisely because I needed to remove the steering arms that I chose to push the bolt through the other way. But it shows that, once you think you have completed the task, you do need to spend a few minutes checking your work.
regards to everyone
Jacko
Post by Jacko »
A very lucky escape! :shock:
