Motronic electrical terminal diagram
Posted: Tue Mar 01, 2005 4:58 pm
by Giorgio
Jeroen i have find from bosch the diagram.The only to do is to find a scanner to put in pc.Where you want to sent you?
Posted: Tue Mar 01, 2005 5:24 pm
By e-mail is always ok or will that be a problem then?
Posted: Tue Mar 01, 2005 6:30 pm
by Giorgio
Posted: Tue Mar 01, 2005 7:06 pm
I'll host the diagram on bmwe21.net for free
Posted: Tue Mar 01, 2005 7:14 pm
by Giorgio
ok i am joking.It was easier that i was thinking.I called bosch dealer in greece and i find a bmw enthusiastic who know very good bmw ecu.And also he find me and he sent me the drawing.I will go there to thank him.He told me that it is common problem when you have icv bad.Some chips and resistans must be changed and he promised me that it will be better than new.
Posted: Wed Mar 02, 2005 9:23 am
OK that's great news.
Something else... the past weekend I was working on a 320i (nope, no 'S') that also had ICV problems.
Motronic switches most things with the mass/ground/negative wire, like the injectors but the ICV as well. We found out that the negative wire had a short (probably due to tear or wear) to the chassis (somewhere?!) so the ICV never stopped! We replaced the wire between Motronic and ICV and it's all fine now!
Posted: Wed Mar 02, 2005 5:35 pm
by Giorgio
Whitch cable is the ground in icv?on 320is?it is one yellow and one white
