Vented discs - worth having?
AndyBaur
My E21(s): 1983 320/6 Baur 5-speed (now gone)
Post by AndyBaur »
I've just discovered the 2.0 auto has the same vented discs as the 323.
Since I'm robbing bits from an auto parts car before it's scrapped, should I get the callipers?
My Baur needs new discs & pads anyway so if the vented discs are worth having I would change to those.
I take it they are a straight bolt on fit.
AndyS
Re: Vented discs - worth having?
Both discs and calipers bolt right on. A set of freshly rebuilt calipers and new discs will brake a whole lot better and the vented discs are better in dealing with heat so in extreme situations like with a fully loaded car going on holiday that may make the difference.
