Calipers Q's - differences + rebuild
Irish_chris
My E21(s): 81 318, 83 316t
Post by Irish_chris »
I have 2 front calipers off a '83 316t I want to put onto my '78 318
Firstly are they the same?
Secondly is there any off the shelf rebuild kits I can get? Seals/bolts/pins etc
Thanks,
Chris
Re: Calipers Q's - differences + rebuild
Pretty sure they're all same. (non vented)
Big red brakes are the people to see about refurb'
I believe there are calipers built by Até and by Girling. You can exchange them as a whole but for a rebuild, you need a dedicated kit. But a rebuild is defo worth while!
Irish_chris
Here's some pictures of the callers I have in question for the rebuild. They have 2 pistons.
Just checked ETK but ETK speaks of Até and LuKas calipers. Até have the pins holding the pads go in from the inside, Lukas from the outside. The lukas examples also have little clips holding these pins in place. They are at the end of the pins so on the inside. Pics are not detailed enough to tell but since they're not rusted too badly you should be able to see a brand name on them.
