high temp
Posted: Wed Aug 15, 2012 9:42 am
by cobbler2u
Temp needle goes onto red.
The problem is that the car is not overheating. Changed temp switch and clocks.
Still same problem.
Need to fix before gaydon :hammer
Re: high temp
Posted: Wed Aug 15, 2012 10:04 am
Usually its the sender. Did you check if the thermostat opens?
Re: high temp
Posted: Wed Aug 15, 2012 10:46 pm
by cobbler2u
Tried still all the same.
The gauge is all over the place . It sways all over the place
Re: high temp
Posted: Wed Aug 15, 2012 10:53 pm
Well in that case at least ur sure its an electrical issue... wiring loom issue if you replaced the sender at the start and the gauge at the end
Re: high temp
Posted: Sat Aug 18, 2012 10:29 pm
by Danny043
I had this problem too, temp needle dancing all over the place. Turned out the earth cable ( - cable) to the battery came loose and just needed to be tightened again. Hope yours is just as easy to fix :smoke
Re: high temp
Posted: Sun Aug 19, 2012 12:09 am
by cobbler2u
Got it fixed I hope
Turn out to be bad / old wiring
Re: high temp
Posted: Sun Aug 19, 2012 12:12 am
by harleytrike
sorted :)
Re: high temp
Posted: Sun Aug 19, 2012 12:15 am
by cobbler2u
Seems when ever Gaydon comes around the car seem to get very temperamental on me
Re: high temp
Posted: Sun Aug 19, 2012 11:18 am
:thumbsup
Re: high temp
Posted: Mon Aug 20, 2012 9:29 am
by cobbler2u
Was a good run to gaydon.
Car run with no problems.
