For M10 1.8 5 speed manual 1982
There are two guibo sizes offered. Can anyone tell me which I need?
http://www.mister-auto.co.uk/en/joint-p ... g1427.html
Guibo / Prop Shaft joint - Which size?
Re: Guibo / Prop Shaft joint - Which size?
78mm pitch circle is what BMWfans indicates for all E21's as far as I can see, also the oem partno under product details matches.
If you try the partnos for the other version in BMWfans it directs to E12-E28-E30 but not E21.
Reck
Thanks Jeroen!
