rack and pinion
Posted: Sun Jan 12, 2014 6:45 pm
by healeyneil
Having converted a couple of cars to rack and pinion steering before ( Healey 3000 and Sunbeam Tiger replica ) I reckoned I could do the same with my Baur.
I used a Mk 2 Ford Escort rack - standard one is 2.9 turns lock to lock, but you can go as low as 2.4. I took out the original power rack, having measured where it sat in relation to the subframe. i made a subframe for the rack
from 3mm steel plate with tube uprights to fit into the holes where the original rack bolted up, then added clamps to hold the rack in place. To suit my M42 exhaust manifold I offset the rack by about 40mm and added a 40mm extension to one side of the rack (readily available in pairs from folk like Rally Design)
The steering column extension was a combination of original E21 and Ford Cortina :D
With the whole lot bolted up it worked beautifully and smoothly, with only one problem - turn the steering wheel right and the wheels went left e_surprised
Once I figured what I'd done wrong :bag I bought a LHD rack and fitted that instead, and it now seems to work fine. As my cars not a runner I havent been able to road test it yet, but pushing it down my drive to put it on a trailer it seemed fine. When I rebuild the front suspension I will measure bump steer, but the new rack is very close to where the original was.
I wont be able to get photos of the rack fitted, unfortunately, as the car has gone into storage while we move house
Neil
Re: rack and pinion
Posted: Sun Jan 12, 2014 10:00 pm
healeyneil wrote:With the whole lot bolted up it worked beautifully and smoothly, with only one problem - turn the steering wheel right and the wheels went left e_surprised
Hahaha
Sounds like a lovely project though!
