Auto to manual
Posted: Sat Feb 22, 2014 10:24 pm
by brennon
On the wiring side of things do I need to make the car think its in park to start? Where is the best place to short it out?
Re: Auto to manual
Posted: Sat Feb 22, 2014 10:53 pm
by drjim
There's a relay under the steering column, you need to remove it and jump two pins. Can't remember what it looks like or what pins are, but just follow the wiring from the selector and jump the ones that the relay connects!
Re: Auto to manual
Posted: Sun Feb 23, 2014 6:16 pm
by brennon
Can I short it out on the connector where it clipped into the shifter?
Re: Auto to manual
Posted: Sun Feb 23, 2014 9:51 pm
by drjim
Better to do it at the steering column so there's less wires to go wrong and ruin your day!
Re: Auto to manual
Posted: Wed Feb 26, 2014 9:48 am
by LeeLee
This might be something I'm going to do to mine if I can get all the parts easy,how have you found the job so far?
Re: Auto to manual
Posted: Thu Feb 27, 2014 8:44 pm
by brennon
I swapped the engine for one with a flywheel and clutch so it was a little easier.
I wouldn't call it a massive job it's just easy to overlook the little bits
Spigot bearing in the back of the crank needs to be installed, it's important to get it in square, I've made the mistake of getting it wrong before and it's a massive pain!!
Rear mount for gear shift had the tab in the transmission tunnel, I'd be 99% sure they all have them.
Clutch resovior needs a mounting made up as it's not on an auto car, also there is a bracket that the clutch line passes through that's missing.
Pedals are easy, seperate them from the mount and you'll be fine!
Don't forget you'll need the propshaft as well.
The only thing that is a real pain is finding this relay ^ but once I've found it for mine I'll be able to advise!
Re: Auto to manual
Posted: Thu Feb 27, 2014 9:41 pm
by LeeLee
If you could that would be great,mines a m10 not m20 as is yours,
Re: Auto to manual
Posted: Thu Feb 27, 2014 10:31 pm
by brennon
To be honest the m10 looks easier as there is more clearance between the back of the engine and the bulkhead so you can see the bellhousing from above
Re: Auto to manual
Posted: Thu Feb 27, 2014 10:33 pm
by LeeLee
I agree with you there just trying to do some research
Re: Auto to manual
Posted: Mon Mar 10, 2014 10:38 pm
by LeeLee
I'm doing mine at the weekend so need to order a spigot bearing but on real oem it's coming up with two available and one discontinued?! :-/ which one
Re: Auto to manual
Posted: Tue Mar 11, 2014 9:16 am
by LeeLee
Re: Auto to manual
Posted: Tue Mar 11, 2014 12:55 pm
by nas80
you don't really need to order it from the dealer as you can easily get them from GSF and places like that
Re: Auto to manual
Posted: Tue Mar 11, 2014 8:27 pm
by LeeLee
Really? Ok usually struggle with parts from gsf
Re: Auto to manual
Posted: Tue Mar 11, 2014 10:03 pm
by brennon
When I did an e32 a while ago euro car parts were spot on, only cost a couple of quid.
Thinking about it that was an m30 which should be the same bearing.
