e34 elipsoid headlights in e21
Posted: Sun Apr 20, 2014 8:18 am
by niall
Has anyone here fitted a set of e34 elipsoid headlights to their e21, i have a set here and have started teh process but they are nowhere near fitting, looks like a tonne of work.
anyone had better luck?
Re: e34 elipsoid headlights in e21
Posted: Sun Apr 20, 2014 10:26 am
by polov8
So far as I'm aware, the quad lamps on an E21 are the exact same units as on a mk1 Vw Scirocco, and having both, I hang out on vwvortex a bit too. These topics both cover the mods done to get the projectors in one of those, and it looks like it'd be similar work to get them in an E21
http://forums.vwvortex.com/showthread.p ... Projectors
http://forums.vwvortex.com/showthread.p ... hlight=e30
Hope this is of help!
Posted: Sun Apr 20, 2014 12:08 pm
by niall
thats a great help, i was looking at it the wrong way, i was going to keep the mounting tabs on the e34 lights and weld on new brackets to the e21 mounts . so glad i dont have to do that
thanks again
Posted: Tue Apr 22, 2014 9:45 am
by niall
for future search purposes, yes e34 lights can be fitted using similar method to the instructions on vw vortex. but it is alot of work, my advice would eb to buy e30 elipsoids
Posted: Tue Apr 22, 2014 9:56 am
by polov8
Those look pretty damn good!
Posted: Tue Apr 22, 2014 6:20 pm
Yup, it's the end result that counts!
Posted: Sat Apr 26, 2014 10:06 am
by cbear1288
I just started trying to make e34 lights fit and i'm with Niall, so much work involved!!! I would love to see how much you ended up cutting Niall.
Posted: Sat Apr 26, 2014 11:43 pm
by niall
i should have taken pics, but it looked so frankenstein that i wasnt proud of it.
The e21 headlight buckets i had to cut back to where they are almost just the flat bit, i cut adn sanded everything off the e34 lights that i could, including one of the blocks that a screw goes in to hold the bulb part on, then i modified where the park light bulb goes in and the holder because that sits exactly where a factory adjuster goes
Posted: Mon Apr 28, 2014 2:07 am
by cbear1288
I can believe that! I think I might just not bother sounds like way to much effort haha. thanks for the heads up mate.
Posted: Mon Apr 28, 2014 7:20 am
by niall
its awesome when done, but alot of effort. if i did it again i think i would keep the lugs on the lugs on the e34 lights and weld on new brackets to the e21 cage.
But if you got e30 elipsoid lights i think it would be only 30 mins work per side
Posted: Mon Apr 28, 2014 2:14 pm
by cbear1288
Yea I bet, which makes it so tempting to do especially since I have a set of e34 lights, now I want to do it again haha. I know e30 ones look so easy!
Posted: Sat May 10, 2014 12:36 pm
by cbear1288
Ok so its happening, ill post some pics of the finished product!
Posted: Sun May 11, 2014 3:30 am
by niall
cool, hit me up if u want any tips
Posted: Mon May 12, 2014 3:00 pm
by cbear1288
will do man, cheers
