Evaorating fuel
AndyBaur
My E21(s): 1983 320/6 Baur 5-speed (now gone)
Evaorating fuel
Post by AndyBaur »
My 320/6 with Weber carb conversion refused to fire up the other day. It turned over fine but there was no hint of firing. A good spark at the plug made me suspect the old 'airlock in the fuel line' issue I experienced when the car hadn't been started for some time.
Sure enough, when I poured some fuel down the inlet pipe into the carb float chamber & down into the pump it fired straight up. All the fuel lines are new (& the connections are tight!) so I'm suspecting the gasket in the fuel pump may be a touch porous leading to fuel evaporating from the pump.
Looking at the BMW part diagrams (& W&N) it seems the gasket isn't available any more. What are you supposed to do in this situation???
Can you just use some old cardboard you have lying about or is there some proper gasket material available from somewhere?
AndyS
Re: Evaorating fuel
Make your own gasket,
Your carparts supplier has sheets universal gasket.
AndyBaur
Re: Evaorating fuel
Post by AndyBaur »
Thanks, I'll give it a go.
AndyS
