Metal cleaning
Posted: Fri Aug 08, 2014 12:33 am
by LeeLee
How do you guys go about cleaning up metal parts,
I have twin 40's I'm going to fit when the e21 comes of the road for the winter
I want to clean them up but the metal still has marks is it worth getting some sand paper or is there a chemical that can be used? There getting there but some of those marks are stubborn and I just want them to look pretty as poss when I fit them
Re: Metal cleaning
Posted: Fri Aug 08, 2014 1:10 am
by nas80
Soda blasting or hours with a fine wirebrush
Re: Metal cleaning
Posted: Fri Aug 08, 2014 6:36 pm
by polov8
I find a dremel on low speed with a selection of stainless wire brush attatchments works pretty well, but soda blasting is best if you have access.
Re: Metal cleaning
Posted: Sat Aug 09, 2014 8:34 pm
by TopCat
I would try a soaking in 50:50 mixture of coca cola and Harpic limescale remover to start with!
Re: Metal cleaning
Posted: Sun Aug 10, 2014 1:16 am
by LeeLee
Sounds like a plan soda blasting would be great but I would have to take them apart I'm guessing
Re: Metal cleaning
Posted: Mon Aug 11, 2014 12:22 pm
by nas80
you mean you have marks on the intake manifolds and not the carbs themselves?
It isn't too bad a job to take them apart. IIRC they are alloy if you wanted you could have them polished and chromed?
Re: Metal cleaning
Posted: Fri Aug 15, 2014 12:24 am
by LeeLee
I ideally would like them just cleaned up as best as possible don't want them polished there of the car I have taken a few bits of in order to clean but still was hard work cleaning and bit worried about going to far with them taking them completely apart in order to dip them
Re: Metal cleaning
Posted: Sat Aug 16, 2014 6:28 pm
by TopCat
New cleaner found today by accident!
I used BBQ grill cleaner on my alloys to remove brake dust etc since my wheel cleaner was empty
worked a treat!
