hesitation when accelerating stalling when cold
Posted: Sat Sep 06, 2014 6:56 pm
by LeeLee
My 316,Had a slight problem of late with stalling when cold and accelerating lumpy at low speeds,I believe it's my carb rubber mount to manifold I can see wet substance around it when I look at the carb,my engine in a m10 from a 83 it's fitted with standard auto choke carb anyone got one or no what part I'm after I've looked on real oem and it's all pretty confusing any help would be great
Re: hesitation when accelerating stalling when cold
Posted: Mon Sep 08, 2014 9:25 am
What is confusing? If you enter either your VIN or choose your build year it will show only one carb and you'll be able to find the right part no without even searching.Then, get a new example from the dealer and you're set for another 20 years.
