Weber on M10 - Failing emissions
Posted: Thu Oct 02, 2014 2:32 pm
Hi all,
I replaced the standard carb on my '81 316 1.8 for a Weber 32/34 a few months ago. Car has sat about being tinkered with since then, had new leads, plugs, dizzy/rotor arm fitted, I have set up the carb the best as possible with the guide found on here, 2.5 turns in, adjust idle etc.
It now drives and idles spot on, but is reading ~8.2% CO on the emissions test.
Being my first venture into carburettor'd cars, I'm not sure where to turn next. Advice from my father includes, change the air filter, check jets are correct, check/adjust dizzy timing and get some hotter plugs.
Is there anything obvious we may have missed or anything which stands out as a more likely fix?
Any help in getting this sorted is much appreciated.
Dan.
Dan.
