Type 1 and type 2 dash
Posted: Mon Nov 17, 2014 7:57 pm
Can anyone help me with a problem I seem to have.
My car is a Type 1 Baur 316, which was converted from LHD some time in the past.
As a result I think it's a bit of a mix of different parts and I'd like to put it all back to being a 'proper ' type 1.
I think it's got a t1 dash, it has the sliding heater controls but the clock binnacle doesn't seem to fit very well.
I had it out to replace some bulbs as it doesn't light up very well, and on one of the pictures I saw on the forum, all the clocks were lit up and very bright (in a post where someone was asking which parts of the dash light up)
It seems on mine that the only light (apart from the Handbrake and other warning lights) comes from 3 tiny orange push fit bulbs, that are housed above the binnacle attached directly to clips on the dash, and some down through 3 holes in the roof of the binnacle.
My problem is that the holes don't line up with the lights. The left hand one is ok, the middle bracket is exactly half way toway far across, so the bulb is only half way above the hole, and the final bracket is at the far edge of the hole, so the bulb sits off to the right of the hole and little to no light passes through. It also seems to me that there should be some sort of filter or attachment on the binnacle, but mine just has 3 open, empty holes.
The trim that fits around the Base of the binnacle and houses the hazard lights and light pull switch also doesn't seem to fit very well where it meets the blower on the right hand side against the door. Just above the blower is a small clip, but there is no corresponding recess for it to fit into on the dash.
When I removed it is clear a previous owner had some problems as the dash has been butchered within an inch of its life to accommodate the light and heater switches.
The trim also has a recess for a fog light switch, but there is no corresponding hole in the dash to allow fitment of the switch, and as such I don't think my car has any fog lights. I certainly can't find a switch anywhere...
So, advice please. Am I right in thinking this is the wrong binnacle, and/or trim piece?
If that's the case would it be best to just get hold of a Type 1 binnacle and trim piece?
How much should the clocks light up? I see no obvious places for bulbs to light up the dials, so does the only light come from above?
Sorry for the long post and lots of questions, never having seen one lit up till I got mine back last week I'm not sure just how it should be.
Probably best if I go take a few pictures if that'd help?
Ta Al
Ta Al
