Indicator Issues
Posted: Fri Dec 12, 2014 10:08 am
by jamiew
Hi guys,
First issue with the e21!!
right so my indicators have stopped working out of the blue, not just one but both, the light or 'click' is absent from the cluster.
I was hoping this could be a fuse issue, but after looking at the info on here, the indicators horns and wipers are together on the same fuse.
However my horn and wipers are working correctly.
Any suggestions as to where i could look next, maybe a broken switch at the end of the indicator stalk?
Re: Indicator Issues
Posted: Fri Dec 12, 2014 10:20 am
Could be an issue with the stalk, but it's most likely to be related to the hazard light switch. Is that in place and functioning correctly? If you disconnect it or if it's broken the indicators might not work either. Also note that the hazard lights are fused separately, check the fuse, also for corrosion!
There are a few related topics in the FAQ section as well as the Top Tech Topics, too.
Posted: Fri Dec 12, 2014 1:15 pm
by jamiew
Jeroen wrote:Could be an issue with the stalk, but it's most likely to be related to the hazard light switch. Is that in place and functioning correctly? If you disconnect it or if it's broken the indicators might not work either. Also note that the hazard lights are fused separately, check the fuse, also for corrosion!
Now you mention it, yes my hazard lights have stopped working.
so first would be to check the fuse for the hazard lights, and this could fix the indicator issue as-well?
thanks for the reply
Posted: Fri Dec 12, 2014 1:40 pm
Yup, they both control the operation of the indicators (basically, the indicators are controlled through the hazard circuitry)
Posted: Fri Dec 12, 2014 2:53 pm
by jamiew
Ok thankyou.
however i am now a little confused as this page states that the indicators are on the same circuitry as wiper sprinkers and electric mirrors:
http://www.bmwe21.net/?page_id=130
Also there is no mention of the hazard switch
Fuse no. Amps Item(s)
15 16 horn, indicators, all wipers & sprinklers, electric mirrors
Posted: Fri Dec 12, 2014 3:20 pm
That's why I said
Jeroen wrote:...Also note that the hazard lights are fused separately...
Fuse 17 as mentioned on the same page
Posted: Fri Dec 12, 2014 4:43 pm
by jamiew
my bad, never heard hazards being called side blinkers before.
Posted: Fri Dec 12, 2014 5:51 pm
What about alarm light then? Better?
Posted: Fri Dec 12, 2014 9:00 pm
by BertjeConti
Sounds like yet another faulty flasher relay.
They seem to go by the dozen.
Posted: Tue Dec 16, 2014 1:17 pm
by jamiew
thanks for all the info guys, i will make an attempt to fix this at the weekend (so annoying it gets dark at 4ish)
