E21 323i Radiator/2002 M20 Swap
Posted: Mon Jan 05, 2015 11:38 pm
I am looking to see if anyone can help me out with a quick question regarding the E21 323i radiator. I have made the decision to use a E21 323i radiator for my M20 swap and before I order one I would like to get some feedback to make sure there is no significant difference. The early model E21 323i cars came with a radiator that has two upper mounting tabs and the lower outlet stubs out parallel to the radiator. In addition, the early model lower radiator hose is two pieced and has a "temp sending unit" between them. The later E21 323i radiator is different than the early version. The late model E21 323i radiators use a single upper mount, the lower outlet stubs out at an angle, and the lower radiator hose is one piece which deletes the "temp sender unit".
Contrary to the pictures I have seen on 2002 forums, I am leaning towards the early version radiator since the lower outlet stub would allow for better clearance, plus using the early radiator and lower hose assembly provides a spot to plug in the electric fan wiring harness. I have linked the two radiator for reference.
Any feedback or additional information for determining the correct radiator would be greatly appreciated. Thanks.
Early version:
http://www.bmwmobiletradition-online.co ... g=11&fg=60
Later version:
Early version:
Later version:
