BMW E21 323i M20B23 swap to M20B25
Posted: Thu Mar 26, 2015 4:14 pm
by jsimon20
Hi everyone,
I have a BMW E21 323i and I want to put a M20B25 from a BMW E30 325i.
I would like to know if someone in this forum already did this swap or if you know exactly what things I have to change in order to do this. I would use everything stock except the ECUthat I already bought a Megasquirt.
I am using a 5th gear dogleg gearbox.
Thanks.
Re: BMW E21 323i M20B23 swap to M20B25
Posted: Thu Mar 26, 2015 5:42 pm
by arshad76
Hi Simon,
This conversion has been done many, many times. Did you try searching for previous topics? You should find everything that you need. I'd say it's a worthwhile conversion and I had it done to my E21 too. Good luck :)
Posted: Fri Mar 27, 2015 5:53 pm
by BertjeConti
"Megasquirt" i like that !
Posted: Fri Mar 27, 2015 8:58 pm
by jsimon20
BertjeConti wrote:"Megasquirt" i like that !
I am trying to get the engine maps in order to start testing, do you know were I can get them?
I will be posting new information here, this might take some weeks.
Posted: Fri Mar 27, 2015 10:17 pm
by BertjeConti
I have maps for my M20B20. Engine runs perfect with these maps.
I presume they will do for a start for your engine.
What ignition setup are you planning ?
Posted: Sat Mar 28, 2015 7:50 pm
by jsimon20
BertjeConti wrote:I have maps for my M20B20. Engine runs perfect with these maps.
I am not decided yet. What do you recommend?
Ok, it would be great if you could send me those maps.
Thanks
Posted: Sat Mar 28, 2015 11:46 pm
by BertjeConti
The easiest ignition setup is a wasted spark setup. You'll need a 6 cilinder coil pack for that. You won't need a cam shaft sensor for this setup and even then choose for a semi sequential injection setup.
I did it this way and i like it because it isn't complicated and much better than the standard motronic.
I''l pm you my ignition and ve tables.
