Battery relocation
Posted: Fri Apr 10, 2015 9:04 pm
I know a lot of you guys have done this successfully.
I have the same set up but I occasionally have starting problems and think it's down to the battery being relocated.what grade wire from where do you use?
And do you use one live to the boot,
a earth in there for the battery and all the other lives in the bay get moved to the starter minus one negative,it just seems to not want to start sometimes but battery is charged and is only a year old I ran it up and down the dual carrage way today it seemed a lot more full of life,I only do 8 mile to work and 8 back on court roads and lots of town pottering about.but this shouldn't be that much of a issue I belive it might be the location of the battery,if it helps I will use any advice you have to see if I can improve the relocation
