E30 Touring with 3.5 conversion for sale
Posted: Sun Apr 12, 2015 1:01 pm
by bealo
Bmw e30 touring still registered a 325 on log book but has 3.5 conversion 86000 miles MOT until August Engine has 112,000 miles M30b35 engine from e34 (locktighted rocker shaft oil feed bolts and tensioner bolt which are common faults) had new plugs, valve clearances done etc. Ecu chipped M30 gearbox E28 M535i 6kg single mass flywheel New Sachs e34 sprung hub clutch E36 328i propshaft E34 non air con radiator and electric fan E46 'purple tag' 067 code steering rack M3 rubber eccentric wishbone bushes Z3 short shifter 3.07 differential Wiring loom done with solder and adhesive lined heat shrink so it will be reliable...and neat :) proper butch engine mount arms on Landrover v8 mounts, nice and stiff. Original e34 airbox not a shitty cone filter.Original Exhaust down pipes modified properly not bodged, although it would make more power with a full twin 2 inch system. Full black leather in good condition on board computer Elec front/rear windows and sunroof Climate Needs new headlining as has sagged and stained a few knocks and scuffs around the car, paint peel on sun roof, scuttle etc are good, engine is smooth and solid, pulls like a train!! A lot of time and money spent on this but I now need a bit more practical family car :( call 07908662601 Car located in Clacton on sea
£2100
Re: E30 Touring with 3.5 conversion for sale
Posted: Sat Apr 18, 2015 7:11 pm
by bealo
sold
Posted: Sat Apr 18, 2015 9:03 pm
by uwbuurman
:thumbsup
