Lots of smoke after M20 engine rebuild!
Posted: Mon Jul 20, 2015 5:49 pm
Hi guys, hopefully some one here can help me out with this issue!
At the end of last year I bought an e21 which had been held up unused in a garage for the past 15years with no previous history, it is a 320/6 model with a 323i engine transplanted into it by the p/o
decided to take the whole m20b23 engine apart and rebuild it from new which included:
honing the block
new goetze piston rings on 5 of the pistons and 1 piston completely replaced with a new one which came complete with rings installed (TRW) due to me being stupid and cracking the edge of the original piston...
polished the crank and installed new big and main end bearings
new seals throught and new head bolts etc.
cylinder head reconditioned by skimming the head and installing new valve stem seals but not the valve guides (stupid I know but somehow missed this out as was my first engine rebuild)
swapped over the k jetronic for Motronic 1.3 off a 2.0 and after initially starting up and having problems with heavily retarded timing due to having 2.0 fuel injection and a 2.3 crank and pistons, decided to swap the ignition over to the original distributor and got the engine to work seemingly flawlessly and pulling nicely through the whole rpm range...
this past weekend I finally decided to get it licensed and back on the road....
but after a few miles of driving I noticed that it was smoking quite heavily under acceleration (bluish white smoke which indicated oil was being burnt).
decided to keep on driving it to see if maybe it was due to the engine still not having run it. But after driving it for 2 days and doing almost a 100miles in it, seems like the smoke is not reducing at all and is quite bad as I can see large clouds of smoke coming out of the back.
upon checking the engine there seems to be quite a lot of valvetrain noise although the valves were all adjusted accordingly.
also the rocker cover breather seems to be blowing smoke and also from the dipstick guide.
today I took the engine top end apart once again to see what is happening in there and seems like all spark plugs are wet with oil and black except for the one above piston 4 which is dry and indicates a nice burn from it (this also happens to be the piston that was replaced!
now Im not sure if the problem lies within
-having worn valve guides( I can move the valves slightly to the side when not under tension)
-or having worn pistons / incorrect ring installation/ worn block bores!
I made the mistake of not measuring anything when installing all components back in the engine and left this up to the engineering shop to check out for me....
what do you guess is my problem here? having the replaced piston being the only one which is giving a clean burn seems to indicate having the other 5 pistons worn or with incorrect rings/ incorrectly installed, but the valve guides also seem to have a small amount of play in them....
here are some pics of the engine after I dismantled the top end today and wiped whatever was easily removable. - everything seemed to be covered in a black oily deposit apart from cyl 4 which had the replaced piston where everything was dry...
honing the block
