E21 coilovers question.
whyismye21broke
- Newbee
- My E21(s): 78' E21
I was just curious about GAZ coilovers. My E21 is stanced at the moment. Coilovers in the back. Cut springs in the front. When I put these GAZ coilovers on my car. Will they go low enough to keep my car at the height it is now. It sits very low. Basically what I'm asking is, will these coilovers be able to sit my car on the ground?
Re: E21 coilovers question.
Look up oldboygarage on Instagram my car is on gaz
- e21-Mark
- E21 Master
You can also ask Gaz to cut the thread further, which is what they did when rebuilding my LEDA.
- e21-Mark
- E21 Master
- Jason_323i
Nope
The track control arms bottom out on the chassis rials before the car sump can sit on the ground
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Alright, here is the question I did not have asked before, but I should have. My English needs a boost every now and then. What is a coilover? Is it the whole "leg"? So shock and spring mounted together? Please educate me!
gazzab1978
- My E21(s): 320 baur
a coilover is basically when the spring goes around the shock absorber,when most people refer to a adjustable coilover it usually refers to the fact you can wind the spring seats down the shock to alter the ride height.
some cars have shocks which bolt to the hubs and can be changed to adjustable coilovers without having to change the hubs, others likr the e21 have the shock inside a tube which is welded to the hub so when fitting adjustable coilovers they need to have a thread machined onto the existing suspension leg so that you can fit a adjustable spring seat onto the original leg.
hope this helps
hope this helps
- jim h
- Newbee
- My E21(s): 1980 320/6 manual and 1982 320/6 auto
Anyone know what the standard (out the factory ride height is for a 320 ?
You want a factory Coilover to sit the car on the ground I dunno it's going to happen people who go that low usually just go customer straight out the gate
