Polyurethane front control arm bushes advice
Posted: Wed Sep 02, 2015 1:57 pm
by M15KYY
Hi guys
I've seen these polyurethane bushes for front control arms, does anyone have these? What are your opinions? Are they worth the money? Are they a pain to fit?
http://www.superflex.co.uk/proddetail.p ... 91-0388KSS
The front control arms are about the only parts on my car that are still original specification. And I hate them! :blablabla if you have poly bushes on the front of your or have had them on previous cars what make were they and would you recommend them?
Cheers
Misky
Re: Polyurethane front control arm bushes advice
Posted: Wed Sep 02, 2015 8:14 pm
by steve5134
From personal experience poly bushes are very easy to fit.
Worth the money and last well :driving
I used the same make as what you have the link too
Posted: Wed Sep 02, 2015 9:54 pm
by drjim
Massive improvement on my Baur, but I did the rod ends and the rear at the same time, replacing the perished 20+ year old ones - car came with receipts from BMW for bushes replaced but they were yellowed with age!
Well worth it. I probably have a set spare still, strongflex ones from the man in Czech. They are a bit of a pig to press in, and I ended up trimming them a bit.
Posted: Thu Sep 03, 2015 9:10 am
by healeyneil
I bought new lower arms which required the conical type bushes. The only ones available came from Eurometric in US. They fitted just fine. Haven't driven the car yet tho.
Posted: Thu Sep 03, 2015 9:33 am
by M15KYY
Thanks for your replies fellas i will get them ordered. I havent had chance to look yet but do the old bushes just press out or do they require burning out?
Posted: Thu Sep 03, 2015 9:14 pm
by drjim
burn them and leave the metal sleeve in until you have checked the bush size. My first set were right to go in the sleeve, but I had whacked it out straight after the burning stage while everything was hot. I then couldn't put the car back together for a week or two until I got the right size ones.
Posted: Fri Sep 04, 2015 6:44 pm
by steve5134
drjim wrote:burn them and leave the metal sleeve in until you have checked the bush size. My first set were right to go in the sleeve, but I had whacked it out straight after the burning stage while everything was hot. I then couldn't put the car back together for a week or two until I got the right size ones.
Can I ask where you got the new sleeves from as I'm not 100% happy with my fix (section of exhaust pipe cut to size) as I cut them out too :(
Posted: Fri Sep 04, 2015 8:55 pm
by drjim
I bought the bushes for the pre facelift e21 which were slightly larger diameter.
Posted: Sat Sep 05, 2015 1:25 pm
by steve5134
Thanks, will look into doing the same
Posted: Sat Sep 05, 2015 3:36 pm
by drjim
I have a spare set for sale
Posted: Tue Sep 08, 2015 9:16 pm
by steve5134
Thanks but all sorted now :)
Will be all back on the car by the weekend
