Cylinder head skimming
Posted: Mon Oct 05, 2015 11:15 pm
Hi all,the haynes manual says that a thicker head gasket MUST be fitted if the head is skimmed on the 320/6.Is this true and if so is it a clearance issue or ignition issue?
My head will probably be having a light skim while it is off due to leaking head gasket.Head currently measures 125.2 so fairly sure it hasn`t been done before.Any comments appreciated.
