Headlamps - H4?
davidvincent
My E21(s): 1982 320/6 Lapis Blau
Headlamps - H4?
Post by davidvincent »
Hi all
Looking for some advice on headlamps please....
I am a complete novice on this subject, can I install H4 bulbs? I understand it that they are H1 as standard - is there a kit to make this work (from 1 to 4 pin connection) or will it pull too much power and cause potential electrical faults?
Thanks in advance.
David
Re: Headlamps - H4?
Sounds like a lot of work to me, I'd fit decent quality H1's or even uprated rally spec ones. Keep in mind that old headlamps with a lot of rust, matted reflectors or chipped glass will make you loose a lot of light as well. I went a bit too far using illegal 80W Philips rally bulbs in new units and this generates more light than the oem Xenon in my E46 without causing an excess of stray light.
davidvincent
Re: Headlamps - H4?
Hmm, so are you aware of what the highest wattage H1's are Jeroen? I assume I'll need an uprated fuse also?
Re: Headlamps - H4?
Haven't changed a thing apart from the bulbs and the fuses are still ok. Only thing I try to do is switch them off a few mins before stopping so the wind can cool them down a but. Haven't really checked but I can imagine some extra heat is generated :P
davidvincent
Re: Headlamps - H4?
Jeroen wrote:Only thing I try to do is switch them off a few mins before stopping so the wind can cool them down :P
Hahahahaha, now that's creative! Good work :)
polov8
Re: Headlamps - H4?
Post by polov8 »
When I drove a mk1 Scirocco (exact same headlamp units as a 6 pot E21) I was running 100w bulbs for a while. Never noticed the lamp units getting hot enough to need too much cooling time! I was running an uprated loom though, as old VW's have notoriously crappy headlamp wiring, and no relays. They certainly worked well, and if aimed properly shouldn't dazzle anyone. Legality be damned!
Andy
davidvincent
Re: Headlamps - H4?
Cheers Andy. Yeah I know about the vw issues, I also own a 1980 type 25 and have heard the horror stories about dashboards going up in flames after people upgraded their lights without upgrading the wiring and adding relays!!
I've ordered some uprated H1 bulbs from Osram for the 320, and I'll clean out the reflectors and lenses, see where that gets me :)
Thanks all.
Re: Headlamps - H4?
:thumbsup keep us posted on your findings!
