weirdly acting clutch (releases early..sometimes)
Posted: Sat Apr 02, 2016 5:34 pm
hi guys,
i have an issue with my clutch and i have my ideas of what it may be, but here´s the symptoms:
i push the clutch pedal down, put 1st gear in, drive away. all as it should. just perfect.
every like 10-or-so times, however, it releases super early, like when i´ve released an inch from the floor it starts to drive away and if im not quick enough i will stall the engine as i dont have time to get proper gas. i think that i´ve once noticed that when holding the clutch pedal down for a bit long time (20 sec or so) the car started roll as if i was releasing the pedal while still having it pushed to the floor.
i´m guessing that theres some spring or so which is supposed to hold the plates in place which looses pressure and starts releasing it without my intention?
anyone recognizes the issue and know how to solve it?
thanks 1000 times ahead as usual
/stefan
/stefan
