E21 Twin Headlights - Help
Posted: Thu Jun 16, 2016 6:01 pm
by phealy
Hi,
I've recently acquired a 1982 323i E21. It currently has a single headlight on both sides. I would like to return it to twin headlights. I have acquired a pair of grills, but not sure what headlights/housings I also need. Any/all advice welcome.
Many thanks,
Paul
Hertfordshire, England
Re: E21 Twin Headlights - Help
Posted: Fri Jun 17, 2016 11:13 am
by Dammizi
if you have the std. metal buckets that hold the headlights , you can use any 5"3/4 headlights off any other bmw. e30 headlights will fit easily in e21 headlight buckets, or maybe also possibly modify the e30 buckets to fit the e21.
otherwise I may have a fully refurb'd set of headlights and buckets for sale or another set in need of a good clean and some paint if interested?
Posted: Fri Jun 17, 2016 6:59 pm
by 105e
would you sell the single headlamps and grill?
Posted: Fri Jun 17, 2016 8:15 pm
by healeyneil
Ive got a spare pair of the plastic grills if you need them, but you should be able to get someone to do a swap, I would have thought
Posted: Sun Jun 19, 2016 11:55 am
by phealy
Dammizi wrote:if you have the std. metal buckets that hold the headlights , you can use any 5"3/4 headlights off any other bmw. e30 headlights will fit easily in e21 headlight buckets, or maybe also possibly modify the e30 buckets to fit the e21.
Hi Dammizi, I've not taken the existing grill off yet, but my guess is I only have buckets for the 7" lights that are on there now. I'll send you a message re the lights that you have. Many thanks
Posted: Sun Jun 19, 2016 3:21 pm
by phealy
105e wrote:would you sell the single headlamps and grill?
Hi 105e, I'm not sure if I'll keep them or not. If I'm not I'll let you know. Need to find twin lamps first. Thanks P.
Posted: Sun Jun 19, 2016 3:24 pm
by phealy
healeyneil wrote:Ive got a spare pair of the plastic grills if you need them, but you should be able to get someone to do a swap, I would have thought
I've got a pair of twin lamp grills, thanks. Just need to sort the lamps.
