323i Has An Extra Chassis Leg!
Posted: Sun Sep 18, 2016 9:23 pm
Converting a 316 shell to 323i, final prep before the shell goes to the painters.
Done the under bonnet brackets for the metering unit and different position for the coil, modded the front panel for the 6-cylinder radiator.
I thought that adding the extra hanger for the second exhaust and the bracket for the fuel pump would be straightforward, but the 323i Has an entire additional chassis leg under the boot floor! Not that difficult to add, just need to drill out some spot welds.... Still need to mod the rear panel for the second exhaust.
Is there anything else i might have missed as I'd hate to have to break out the welder again after the shell has been painted....
