Need help building a 2.7 m20
Posted: Sat Sep 24, 2016 7:05 pm
by 323i-killer
As in the title need help building an 2.7 m20, I will be keeping the k jet system and using a 731 head. Cheers
Re: Need help building a 2.7 m20
Posted: Sun Sep 25, 2016 1:24 pm
by e21Keith
I had plans to do the same using the forged 324d crank but never progressed. Car coming back from paint and I need to build a engine for it!
Posted: Sun Sep 25, 2016 1:37 pm
by gerrit323
As a base you need the 122hp 27 6e a type eta block .. plug and play with the 731 head .. if you balance things like cranck conrods ald rework the heads in and outlet ports and put in a mild cam 170hp and a good amount of extra torque is available
Don't use the 129hp 27 6k b block because the pistons used in that type eta are not usable with the 731 head
Posted: Sun Sep 25, 2016 1:40 pm
by 323i-killer
So then it's pretty pointless as I might aswell stick with the 2.3 bottom em as still achieve 170bhp
Posted: Sun Sep 25, 2016 1:41 pm
by 323i-killer
Or would I get more torque by going down the 2.7 route?
Posted: Sun Sep 25, 2016 1:42 pm
by gerrit323
You will have more torque .. thats all .. if you want more power like 200hp or so you need to go the l jet route and use the 129hp block with 885 head .. i did that in my ex e30 and had 204hp and 278nm torque
Posted: Sun Sep 25, 2016 2:00 pm
by 323i-killer
Oh right any chance of gaining 200bhp with the k jetronic?
Posted: Sun Sep 25, 2016 3:57 pm
by gerrit323
Don't think so .. the K-jet itself is the main bottleneck .. you can use the 129hp version and the 885 head with the e21 323i intake and k-jet but the diameter of the intake tubes are smaller than the inlet ports from the 885 head .. so you already lose some capacity at that point also
Posted: Sun Sep 25, 2016 4:07 pm
by 323i-killer
I think by using the porsche k jet bits and Merc injectors 200bhp can be achieved
