Sudden low oil pressure ?
Posted: Sun Dec 04, 2016 11:07 am
Last evening a weird issue happened. As I was driving (in city traffic, low speeds) suddenly I saw VERY LOW oil pressure numbers on the digital instrument. )
Numbers such as 0.3-0.4, normally meaning that I should stop the car immediately. However, the dash oil light was not on (before summer, when that issue with my oil pump had happened, I remember that the dash oil light was coming alive whenever the digital gauge was falling lower than 1.0). Also the sound of the engine was absolutely normal.
So I drove home (was lucky enough to be already quite close to my parking lot), and turned the engine off. Checked the oil, was not too low, however I added some more. I turned the engine on again some 10 minutes later. Everything ok. Today I drove about 4-5 km, everything normal.
Could this be some burr, some tiny small metal part, obstructing the instrument, misleading it to give wrong figures?
As we recently replaced the piston rings, in order to reduce too much oil fumes, The engine was opened, so I am in the period of having to do about 1000 km before changing oil and setting up valves (I haven't done more than 600 km yet from that point, thus oil has not been changed after engine opening)
