Negative camber
Posted: Fri Jan 27, 2017 5:38 pm
by healeyneil
Has anyone ever introduced a little bit of negative camber in their front suspension by moving the mounting point of the lower wishbone out by a few mm ? It would be easy to file out the hole, then weld washers in the correct place. As a road car I don't really want to fit adjustable struts and lose the insulation the std top mounts have. I just feel that mine almost has positive camber as it sits now
Cheers, Neil
Re: Negative camber
Posted: Sat Feb 18, 2017 12:55 am
by healeyneil
Has no- one ever tried this ?
Re: Negative camber
Posted: Sat Feb 18, 2017 9:45 am
by BertjeConti
Yes, i did it that way, check my E12 tread:
look here
and here
for the full story
Re: Negative camber
Posted: Mon Feb 20, 2017 9:17 am
by healeyneil
Thanks. That's moved more than I thought !
Re: Negative camber
Posted: Mon Feb 20, 2017 10:05 am
by BertjeConti
Yes, i needed it because the new wishbones i used are 5mm shorter as the stock ones, bad reproduction.
