Clutch troubles
Posted: Mon Jul 17, 2017 11:54 am
Hi guys, looking for a bit of advice before I shell out some cash.
I took my Baur off the road for the winter at the end of October. Due to ill health I only got it back on the road in early July. It's been moved out of the garage a couple of times and warmed up, during the last 7 months, and every time I found that it would go into gear ok, but when I rolled it out it would stall as I stopped, and the clutch pedal wouldn't return. Taking it out of gear, restarting sorted it and I could move the car back into the garage.
I assumed something was sticking, so used it carefully on the road for about a week, covering around 100 miles. Then at the end of the week, whilst on a run, it wouldn't go into gear. I kept it rolling, and eventually got 2nd. Then it'd be ok for a little while, and then play up again. We headed home, and it ended with me stuck in 2nd, and a terribly hairy drive as I couldn't stop as the clutch stayed flat to the floor, and I couldn't change gear. it was a case of 'coming through whether you like it or not...'
I know nothing about mechanicals, and am not capable of fixing this myself. I've tried to do some research, and I suspect that it's a fault with the slave cylinder, as there is no leaked fluid on the garage floor, which I gather would indicate master cylinder failure?
There's no smell of burning clutch, so i'm not thinking it's any problem with the clutch itself.
I've got a mechanic friend who has offered to do take the car and do it for me, but I need to know what bits to get hold of.
For info the car is a '79 Mk1 Baur, which has had a 2.0 m10 from a 2002tii fitted. It's running twin Webers and has about 170bhp
I'm thinking it'd be best to change the master and slave cylinder at the same time, if one has failed, then no doubt the other will go sooner or later.
I've looked on W&N and they only offer the LHD master cylinder. My car was originally lhd, but was converted to rhd. Is it likely that this master cylinder will fit?
I know W&N have had troubles with various parts, and that a lot of rubber parts have been inferior and failed early. Are the W&N clutch cylinders up to the job, or will the rubber seals fail early too?
Are there any other bits I should look to change at the same time? Is it worth an upgrade to braided hoses whilst the system is in bits?
Thanks in advance for your help.
Al
Al
