fuel sender
PeterCS
My E21(s): 82 BMW Baur
fuel sender
Post by PeterCS »
I bought a new sender. However the new sender has two hose connections and my old one had only one!
I am guessing that i should plug the larger connection.
Thoughts?
Here is a pic of the old versus new.
thanks,
PeterCS
1982 315 Baur
Peter Churchill-Smith
Re: fuel sender
BMW is more and more trying to combine parts, looks like you get the sender from the fuel injection versions these days, which has a return pipe which is the smaller one indeed. Make sure to stop it off or you're having fuel smells and or leaks... otherwise should be fine.
PeterCS
Re: fuel sender
Post by PeterCS »
Joeren - are you sure I should not be blocking the larger pipe. The larger pipe takes a larger hose than the one I originally had.
thanks for the prompt reply.
Peter
Re: fuel sender
Could be but you should be able to see which goes where. The pick up pipe is the one that goes all the way down and has a mesh filter.
