Engine bay firewall
Posted: Wed Jan 31, 2018 1:54 pm
by Vic
Hey all
So the E21 RHD engine bay firewall insulation mat is now obsolete, and lucky me my 323's crumbled when removing to have the bay sprayed :protest .. I'm now having to search for the most suitable material to reinstall; the original had the black butyl rubber as the top layer (to protect from water ingress), and goes a tad low down into gearbox tunnel. Last thing I want to do is fit an absorbing material which eventually holds water against the bay and interior partition :wtf
Wondering if any other member has had the privilege of solving this issue lol
Appreciate any advice guys, thanks
Re: Engine bay firewall
Posted: Wed Jan 31, 2018 8:05 pm
Curious as well! The LHD version was being made some time ago, not sure if they're all out again yet, but the quality from BMW was rubbish, so I'd like to find out about alternatives as well!
Posted: Wed Jan 31, 2018 10:35 pm
by Vic
I didn't think I'd struggle this much to source a replacement, I can't reinstall the rebuilt engine until the mats in placed..
I'm looking into material used for marine proposes, between 10-20mm and closed cell foam, this would have the heat and waterproof properties required, and in an oem black finish.
Spoke to an insulation company, and they recommended Dynamats Dynaliner however the foam on this would blatantly absorb water and after some time the firewall panel would form areas of rust.
Posted: Thu Feb 01, 2018 10:42 am
by Vic
Managed to source a suitable material guys..
https://www.carinsulation.co.uk/product ... n-foam-5mm
Spoke with Paul at the firm, is helpful and very knowledged on the subject, and the stock isn’t expensive either :)
Posted: Thu Feb 01, 2018 10:54 am
:thumbsup :thumbsup :thumbsup
Thanks for the info!
Posted: Thu Feb 01, 2018 11:28 am
by Vic
No probs Jeroen, thanks to you for creating such a great forum for the E21 community!
Posted: Thu Feb 01, 2018 11:53 am
My pleasure! Just hoping for a bit more viewers, people are shifting to the superficial grounds of Fleshbook and the likes...
Posted: Fri Feb 02, 2018 9:14 am
by uwbuurman
I will be one of the last dinosaurs here, but I still like this forum better!!!
