M20b20 engine stand
Posted: Sun Oct 28, 2018 10:39 am
by bealo
Hi guys
Does anyone know what size bolts to use to mount a m20b20 to an engine stand?
I believe itβs m12 x 1.75 but not sure on length
Am I right in thinking it mounts to the stand using the gearbox bolt holes?
Can I mount it without taking off the flywheel and clutch?
Cheers Iain
Re: M20b20 engine stand
Posted: Sun Oct 28, 2018 11:29 am
by Wilmo
Indeed, you use the gearbox mounting holes. Here is a hint about the bolts:
http://bmwfans.info/parts-catalog/E21/E ... ing_parts/
There are in the internet some examples of engines mounted to the side.
If I look at my old pics of mu M10 than there is not too much place actually to leave the clutch and flywheel on:
Posted: Sun Oct 28, 2018 5:51 pm
by uwbuurman
No, you do want to remove clutch and flywheel8
Posted: Sun Oct 28, 2018 8:26 pm
by bealo
Ok thank you, any idea on length off the bolts required?
Posted: Sun Oct 28, 2018 8:40 pm
by Wilmo
Have you had a look at the link? And it depends as well from the engine stand you have.
Posted: Sun Oct 28, 2018 9:31 pm
by uwbuurman
How about the lenght of the stand arm, and then a good inch.
Posted: Mon Oct 29, 2018 8:24 am
by bealo
Thanks guys most helpful
