Page 1 of 10
				Bealo's 320/6
				Posted: Sat Sep 26, 2020 3:50 pm
				by bealo
				So after buying this 1982 3206 2 years ago (2018) I've finally got it back to my house to see how rotten it really is!
It came with no interior, no gearbox, no bonnet and a very seized engine with no sump and many bits missing. On the other hand parts it did come with included BBS Mhale wheels, BBs splitter and rear pop outs
I knew it would need extensive welding if it was ever to see the road again but I'm up for the challenge. Im very new to welding but have watched many videos and been practicing and finding my best settings...... so far so good!
 935E4FCE-63B1-4451-BCED-F83D71FFC8B4
935E4FCE-63B1-4451-BCED-F83D71FFC8B4 by
Iain Bell, on Flickr
 C4B06A2E-B9DF-4668-804B-E1A16CB4E5E3
C4B06A2E-B9DF-4668-804B-E1A16CB4E5E3 by
 8CEE62E9-A29A-4021-8675-351689474CB8
8CEE62E9-A29A-4021-8675-351689474CB8 by
In the 2 years since i bought the car I have been collecting parts including an engine which i  have fully rebuilt! This was my first ever engine rebuild and I thoroughly enjoyed it. Everything has been stripped and cleaned, Its had a full gasket set, big end bearings, piston rings, valve stem seals, water pump/timing belt, a couple of new valves, cylinders honed and head skimmed. The originak solex carb ditched replaced with a Webber 38 DGAS
 6BF991A2-0BA9-4C95-87A8-A3AEBBF8E63D
6BF991A2-0BA9-4C95-87A8-A3AEBBF8E63D by
 4372D55B-BAF0-4EC2-9E70-2FF34EC10E5B
4372D55B-BAF0-4EC2-9E70-2FF34EC10E5B by
 9BF52823-2C3C-4A56-B0E9-15057244C0CC
9BF52823-2C3C-4A56-B0E9-15057244C0CC by
 205FD3B0-C78C-4FA4-BA78-84652A91B701
205FD3B0-C78C-4FA4-BA78-84652A91B701 by
 916936EA-2128-49A8-8A88-0CA2955729AF
916936EA-2128-49A8-8A88-0CA2955729AF by
This spurred me on to weld up a jig to test fire it.
 so out came the welder......
 AA5C984A-354C-41E9-A4DC-F64CFC04FDAD
AA5C984A-354C-41E9-A4DC-F64CFC04FDAD by
 21F6B02E-2D60-412F-8E85-8038E482928E
21F6B02E-2D60-412F-8E85-8038E482928E by
On the Jig ready to ... or so i thought  It totally slipped my mind that the starter needs the gearbox to bolt to and i didnt allow for this in my jig design
More to follow....
				Re: Bealo's 320/6
				Posted: Sat Sep 26, 2020 8:28 pm
				by BertjeConti
				Defenetly going to follow this build.
I also did a rebuild/overhaul of a M20B20 engine without knowing it's history, bought the engine in the first place for parts for a carb to injection conversion, which i did a few years ago (megasquirt).
This year the refurbished engine took place in my car and it's running great.
Good luck with welding the cas
				Re: Bealo's 320/6
				Posted: Sat Sep 26, 2020 8:45 pm
				by uwbuurman
				Mee too, looking forward to your progress!
				Re: Bealo's 320/6
				Posted: Sat Sep 26, 2020 9:23 pm
				by bealo
				so for last couple of weeks I've been stripping and assessing exactly how much needs to be done to the e21
The list so far....
Repairs to valence (although I have another one coming now)
Repairs to front panel
Repairs to bulk head
Repairs around front windscreen
Replace both outer sills
Possibly replace drivers side inner sill
Repair/replce front floor pans
Rear inner arch tub repairs
Replace boot floor
Repairs to rear panel around drivers side rear light
Its a pretty daunting list for someone with limited experience in welding but taking my time and starting at the front with the easier repairs that wont be seen and lots of practice pieces on scrap
Ive also started the first repairs to the front panel
 I still need to get pictures of this but very pleased with the result so far
Ive been treating a lot of surface rust in the engine bay with Dimitrol 800
I cut the drivers sill off to reveal... another sill and some horrible repairs
 108FD680-06A0-421F-A6D9-DEE1FCEEDAAA
108FD680-06A0-421F-A6D9-DEE1FCEEDAAA by
 44F91D52-823B-4E4E-AAE8-04CAA4EA6446
44F91D52-823B-4E4E-AAE8-04CAA4EA6446 by
 0E6A5CE7-5699-4389-966B-9AD1FED10A1B
0E6A5CE7-5699-4389-966B-9AD1FED10A1B by
 D0ED5C6E-70D5-4753-AC89-8FC71C145610
D0ED5C6E-70D5-4753-AC89-8FC71C145610 by
 4D26E80B-4A71-4E5A-AD5E-012ADFD2332F
4D26E80B-4A71-4E5A-AD5E-012ADFD2332F by
 F8DFFA14-A298-45DE-B252-308BDE3F8636
F8DFFA14-A298-45DE-B252-308BDE3F8636 by
 7AF5D77B-58A1-4622-B040-0E3725EFC18D
7AF5D77B-58A1-4622-B040-0E3725EFC18D by
 824D9DFB-8704-4A79-8394-31C5939E5156
824D9DFB-8704-4A79-8394-31C5939E5156 by
This week  I got a chance to have a look at the engine and bolted up the gearbox and starter motor for a test fire
Unfortunately it didnt start and further investigation revealed there was no fuel getting to the carb. maybe lack of pressure??
The mechanical pump seems to be operating as it it should so going to have another go this week with a submersible pump from the jerry can to get get some pressure
 3BB081A5-8382-4F63-AB21-0CBC2E9FB843
3BB081A5-8382-4F63-AB21-0CBC2E9FB843 by
				Re: Bealo's 320/6
				Posted: Sat Sep 26, 2020 9:28 pm
				by bealo
				a couple of pics I forgot to add of the bare engine bay and some rust treatment on the front panel
 5F291657-3610-4B26-8320-3AED70114D2A
5F291657-3610-4B26-8320-3AED70114D2A by
 764ED946-19DD-4AAF-9773-D04ADD9C2B87
764ED946-19DD-4AAF-9773-D04ADD9C2B87 by
				Re: Bealo's 320/6
				Posted: Sat Sep 26, 2020 9:30 pm
				by uwbuurman
				All to familiar. I guess you've seen my 323i topic? May come in handy, for some details.
But, nice work so far!!
				Re: Bealo's 320/6
				Posted: Sat Sep 26, 2020 9:42 pm
				by Wilmo
				Bertjeconti mentioned it already and when my car was in a slightly smaller overhaul I decided to take the step. You learned already to weld and you don’t seem to be afraid of a challenge. What about converting the engine from carb to injection? Bertje made about 140hp out of his M20B20, might be even more out of his freshly built new engine.
I left stuff a bit less original and I should have somewhere between 140 and 160 out of my M10B18.
				Re: Bealo's 320/6
				Posted: Sat Sep 26, 2020 10:05 pm
				by BertjeConti
				"Uwbuurman" didn't have any welding experience when he started his 323i project, he learned and learned and did a great job in the end, which resulted in a stunning like new car.
take your time, don't rush.
				Re: Bealo's 320/6
				Posted: Sun Sep 27, 2020 10:09 am
				by bealo
				Uwbuurman yes I’ve seen your build... very impressive and I’m sure I’ll be using it as a reference
Wilmo, I was looking for m20b25 engine as it seemed an easy swap but can’t seem to find one at a reasonable price.
I’ll stick with stock for now but not put off exploring other options at some point
				Re: Bealo's 320/6
				Posted: Mon Sep 28, 2020 1:14 am
				Thanks for sharing all your findings and experiences sofar, much appreciated! I agree with the speakers above, take your time to figure it all out and do things right, the car deserves it! We'll try to be there for you for technical and moral support
				Re: Bealo's 320/6
				Posted: Tue Sep 29, 2020 2:38 pm
				by bealo
				Thanks will definitely need the support!!
Hopefully I’ll get a couple of evenings on it this week
				Re: Bealo's 320/6
				Posted: Sat Dec 26, 2020 5:08 pm
				by bealo
				Quick up date......
Ive not had a lot of time on it over the last few months but the time I have had Ive been finishing up the front panel repairs and practicing welding
you'll in the pictures my first go at a repair with lots of holes burnt through. More practice and adjusted setting on the welder then i cut that piece out redone.
not brilliant quality but getting better, by the time I got to the passenger side of the front panel my fabrication and welding skills were improving
 F8E5BE33-7299-4D22-89F2-8F46C91CD399
F8E5BE33-7299-4D22-89F2-8F46C91CD399 by
Iain Bell, on Flickr[/img]
 7237E3AF-D85A-46D8-9D2D-72313FDFFC31
7237E3AF-D85A-46D8-9D2D-72313FDFFC31 by
Iain Bell, on Flickr][/img]
				Re: Bealo's 320/6
				Posted: Sat Dec 26, 2020 5:38 pm
				by bealo
				I was getting a lot of holes in my welds which turned out to be not enough gas and contaminated metal. got this sorted and welded on new brackets for the plastic inner arch trims and a couple more small patches
more rust treatment applied and completly stripped the front end as my wife bought me a roll over jig for my birthday
Doors are now off and the whole loom front to back is out, jst back end to strip and she will be ready to go on the jig
 F4B0F27B-20A1-4D4D-BF4C-670186964C90
F4B0F27B-20A1-4D4D-BF4C-670186964C90 by
 A32994F1-701D-4A79-851E-388BB6B9BC6C
A32994F1-701D-4A79-851E-388BB6B9BC6C by
 E08A491F-59B5-4CDA-AC84-EA94E574115E
E08A491F-59B5-4CDA-AC84-EA94E574115E by
 9E455C86-6472-4924-BE6F-E1ABCB92D4C3
9E455C86-6472-4924-BE6F-E1ABCB92D4C3 by
				Re: Bealo's 320/6
				Posted: Sat Dec 26, 2020 5:40 pm
				by bealo
				Re: Bealo's 320/6
				Posted: Sat Dec 26, 2020 6:52 pm
				by BertjeConti
				Nice to see some progress.
"my wife bought me a roll over jig" so you have full support which is great.
