e21 Gearbox Oil
Posted: Tue May 18, 2021 5:57 pm
by guerciotti
Hi all,
Wanted to do change the gearbox oil on my 316 1.6 4 speed gearbox. The manual calls for 80W oil - am I correct in assuming LIQUI MOLY GL4 80W mineral oil would do the job ok? Alternatively does anyone have any other recommendations?
Thanks
Re: e21 Gearbox Oil
Posted: Tue May 18, 2021 9:07 pm
Yup, or Castrol Transmax in the same spec for example. Hint: before removing the drain plug, remove the fill plug. Drains easier and prevents running into issues if the fill plug fails to come out properly. Never encountered that problem myself but I've heard some stories...
Re: e21 Gearbox Oil
Posted: Tue May 18, 2021 9:14 pm
by uwbuurman
I use the Kroon Classic for older cars.
Re: e21 Gearbox Oil
Posted: Wed May 19, 2021 11:07 am
by guerciotti
Thank you both.
