Oil Pressure Light 1981 US 320i
Posted: Wed Oct 06, 2021 7:08 pm
Greetings from Portland Oregon USA!
I searched for old posts about this but did not quite find what I was looking for.
Also, as a new user, I'm excited to interact more directly with this forum and decided to make a new post.
The car:
1981 US 320i with the stock oil pressure idiot light, no oil pressure gauge.
275k miles
no major modifications
no recent work done
I bought this car a few weeks ago and am waiting for parts in the mail for a thorough tuneup and cooling system refresh.
In the meantime, driving it has been a real treat.
As a BMW motorcycle guy, this is my first BMW car and REALLY like it.
Starting the car the other day I was alarmed to see the oil pressure light settle to dim after being bright at startup.
I was concerned that the light was indicating actual low oil pressure since it did not turn off with revving the motor.
I turned off the car as a precaution.
The oil level was fine and the oil itself looked ok.
I suspected the sensor and unplugged it to clean the connections.
After restart,the cause appears to be the light circuit grounding out at some point because the light stays dim even with the sensor unplugged!
That felt like a huge relief!
Do you agree with the above diagnosis?
If so, here are the questions:
1.) Where does the oil pressure light circuit ground to?
2.) Any common grounding problem points for the oil pressure light circuit?
At 275k miles, I'd prefer a mechanical oil pressure gauge to the idiot light
3.) Any hope of sharing an existing hole through the firewall for a mechanical gauge hose?
4.) If sharing a hole is not realistic, any recommendations on where to drill one?
Thanks much for any input or comments!
Cheers and happy driving
-Marcus
The car:
275k miles
no recent work done
-Marcus
