Starting issues
Posted: Mon Dec 15, 2025 7:04 am
Recently replaced engine harness on '83 320i, after a whole shebang of starter replacement issues. However starter does not engage now, everything is wired in correctly, however when i turn key to start position all that happens is a single click, fuel pump engages, dash lights up and I can bump start the car. I do have a new starter relay on the way but as for now I am out of other ideas as to what the problem could be, i did have to connect the old ecu port to the new(er) harness, and the only thing i could've wired on that wrong was the ground wires. the ground from the engine itself is in good condition, distributor coil is only 1&1/2 years old, battery is 3 years old and was checked to be in good condition. When the starter relay gets in I will be replacing the fuel line from the W.U.R., as it is starting to crack. As for any other potential issues it could be I am welcome to suggestions.
