Coilovers on e21?
- Jason_323i
higher spring rates and different valved dampers is about it. You should speak to gaz. Normally if you want a specific ride height they will ask for the compressed height of the spring.wicked wrote:Hi,
What coils do I need in the front for a M30 conversion.
- Length ?
- Preload ?
Is it neccesery to use these smaller negative demping spring
(the smaller ones). The GAZ coil-overs shown in this topic don have them !!
Anybody a good adres for coils.
The small springs you sometimes see are keeper springs, they help the spring captive when the shock is at its full extension. They only need them if the free length of the spring is small enough that it rattles around, so it totally depends on the spring/shock combination.
bumping this back up. Ill be in europe for 2 1/2 months which includes about 2 weeks in the UK, so im thinking now might be a good time to buy a set of these and bring them back with me.
These guys are selling them for 845 pounds which works out to be about $1600 AUD at the current rate. Seems like the price has come down a bit.
http://cgi.ebay.com.au/BMW-E21-GAZ-Shoc ... 4ced013213
anyone had any dealings with the company?
edit: and ive just seen this thread.
http://bmwe21.net/forum/viewtopic.php?t=9973
Seems like a go then.
Anyone in the UK got a pair of strut tubes?
- e21-Mark
- E21 Master
Ill gladly pay for them if anyone does come across a set, welcome to keep the inserts, just need the tubes. I wont be over there till probably august (at the end of my trip).
Metrix Motorsport
FYI Metrix Motorsport does excellent coilover work as a matter of fact they do a lot of the work for some of the major vendors. Previously just a sub contractor they have been busy expanding and aare in the process of updating their website so it might be a little while.
They also rebuild and ramp differentials, build hybrid race engines etc.
You can contact Rob at Metrix directly, (818) 296-7528. tell them Pete from Hawaii sent ya!
- E21 starter
- e21-Mark
- E21 Master
- E21 starter
