316 Historic rally project
Now I've worked out how to post pictures, here goes!
Currently being prepared for Classic Rallying. Lots to do still, and lots to learn!!
Front suspension. Bilstein sports. Poly bushes. Quick rack. 323i vented discs. Uprated springs.
Rear Bilstein Sports 2 1/4" springs. Polybushes. Solid beam mounts
Fuel and brake lines inside. It's a nice clean strong shell. Looks like it was rustproofed from new.
I want to keep it as an M10 engined car. Webers etc.....
Nice shiney new manifold ready to fit.....
Corbeau GTS seats on E21 runners. A right pain to fit at the correct height.
- e21-Mark
- Mihajlo
- My E21(s): 1982 315swap323i
Re: 316 Historic rally project
Markw wrote:
why are your bushings purple? wich brand are they? are they new?
- DrGonzoPOW
Bushes on the rear trailing arms are off the shelf Superflex ones. Rear beam mounts are homemade from nylon, so have some 'give'. (Not much!)
There seems to be bugger all available for the front though, so I've had to turn these from bar material supplied by Superflex. It's bloody expensive and there's lots of waste. Outer TCA/ roll bar mounts are stock new BMW parts with machined up Superflex material to fill the 'void'. You can't really make these too solid as there needs to be some compliance because of the geometry of the front end. Inner TCAs are also machined from bar stock.
Mark
Mark
- Mihajlo
I'm looking forward to buy these stuff so I'm wondering did somebody try it already to share impression...
http://www.iapdirect.com/product.php?productid=42000
I like to see hellaflushed e21 around.
Brakes must be period and from the 'model' concerned i.e. an E21. These comply and are Group 1 legal as well. Pads are Mintex 1144s at the moment.No upgrades planned for the brakes?
Don't think it's worth going to 323i rear discs. Handbrake will suffer and is important for this sort of event. I'll have to see how it goes.
Mark
OK clear, at least this setup is vented and rebuilt which is a great help.
I did two trackdays with these mintex pads and ended up burning them in both cases so they're not my favorites but others have better experiences so better test 'em first.
If you too encounter problems good suggestions from own experience are Ferodo DS2500/3000, Carbone Lorraine and Hawk.
- Sierpien
- My E21(s): C1 Turbo Alpina tribute, 316 Sepiabraun
- Facebook page: https://www.instagram.com/fedecx5aa/
Excelent work!!!!!
Alex von Falkenhausen
- Blackadder
Looks very nice!
What kind of Webers are those?
Easy to install?
is it a 1600 or a 2000 engine?
Easy to install?
