I plan to get some alloys asap with a set of 13" basketweaves, I was considering 15" but that means the hassle of correct offset and wheel spacers unless I shell out for the correct offset alloys which are not easy to find in the UK. Plus as a younger driver, insurance companies love modifications so they can extort even more from me so thats another reason I think I'll go for 13". The main thing I need is driver and passenger seats which have worn through badly and are currently used with seat covers, I don't even care if they aren't recaros- I just want seats! The suspension is set to be lowered 4cm and stiffened as the stock suspension is in a bad way, and I might swap the bushes out at the same time.
I'm also looking to swap out the sound system as I like a fairly decent system in my cars. At the moment I have a spare amp and head unit which I plan to hook up to new 6x4s in the front, and run two new 6x4s in the rear shelf. I may later on put a sub in the boot using my amp on that. Any advice on any better configuration would be greatly appreciated.
Any advice/comments gladly recieved, cheers.
