2.5 Conversion
2.5 Conversion
Im currently in progress of installing a 2.5 engine just need a little help and advice on a few things. So here we go...
Fuel pump, i was told that i would need to change it if im swopping engines around cz e30 2.5 has electronic system and it runs at lower pressure than e21 fuel pump. but looking at certain website like...
http://forums.bimmerforums.com/forum/sh ... ?t=1045649
...says you can use the same one but need to check the pressure. the e21 runs at 5bar and e30 engine runs lower like 2bar or 2.5bar.
79' BMW E21 323 M20B25 lives!!!
- e21-Mark
- e21-Mark
- e21-Mark
- --ALPINA--
You need the E21 323i waterpump which has 2 outlets to run its system!!! the 325 has 1 outlet -- look below..
323 Water pump -
http://www.realoem.com/bmw/showparts.do ... g=11&fg=35
325 Water pump -
And with the fuel pump the 325 is a 2.5 bar, 320 is a 2.0bar so if your having a 5 bar fuel pressure regulator and the 325 on the injector rails your gonna have fuel leakage in the injectors cos your running a total of 7.5 bar which is no good for the system and will over fuel which eventually cause issues over time, i cut my fuel pressure regulator off and direct it thru the fuel filter to the injectors upfront!!
J
323 Water pump -
325 Water pump -
J
- e21-Mark
- --ALPINA--
325 has one outlet from the waterpump which connects to the thermostat housing, and on the 323 the waterpump has 2 outlets, one also goes to the thermosat housing and the other goes to the expansion tank!
And the expansion tank on the 325 is connected to the thermosat on the underside!!
which is why a waterpump from a 323 is needed
323i setup
http://www.realoem.com/bmw/diagrams/c/d/8.png
325 setup
http://www.realoem.com/bmw/diagrams/c/d/7.png
now you can see the difference.
323i setup
325 setup
- --ALPINA--
No kit, the box was custom made for me at a company called Tate & Lyle (sugar refineries in east london) i was an on-site engineer and they custome made everything there as its a 24hour site with all machiners for repairs e.t.c. i was well impressed so i deisghed it in a way that i have my fuel gear in the boot, also easy to change the fuel pump and filter rather lying down flat under the car...
Nice eh!!
J
Nice eh!!
J
