Thought that id better get on with the engine swap - progress isnt up to the standards of some of you guys. It was raining lots and there has been plenty of headscratching and pondering.
heres some pictures
the e34 is so well built that it actually took two days to get the engine out without damaging it!
I jumped on its roof afterwards though. :p
I moved the 5 series outta the way then started stripping the front off the e21. It seemed to take forever - stupid rusty bolts.
as most of you lot know, the m50 engine sump sits way too low when you use the stock 323i e21 box due to the angle so I sent the sump off to be modified. the sump has been made shallower and then a wing added onto the side to keep capacity up.
heres a pic of matey welding it up.
I actually forgot to take a pic of the sump - but will do tomorrow! I havent also taken pics of stuff I did today such as replacing the front subframe with the 323i one, removing the battery tray and general cleaning.
Stuff left to do.
modify the oil pickup tube (needs shortening)
fit a fuel return line.
put the fuel pump on and wire it up (theres no mounting lugs!)
battery relocation to the boot - 5 series cable just fits - only just lol
fit new clutch kit / flywheel / pilot bearing
put the engine mounts on.
wire up rad fan
take off old prop / fit the m20 prop.
when the qauiffe LSD diff arrives ill have to stick that on as well.
fit power steering pipes (this is easier then i thought!)
