Brake problem
Eire21
Brake problem
Post by Eire21 »
Folks,
I have an 82 316
The car has been laid up in the garage for a week or two, went to take it out last night for a run and the brake pedal went straight to the floor. The brakes seem to work ok but they do not bite until the pedal is practically right down?
I checked the fluid level and it was fine, then checked the garage floor for any leaks. Also checked around the MC for leaks but nothing obvious there either...
Any ideas what the problem could be?
Thanks
Rich
Re: Brake problem
Air in the system maybe? Check flexible hoses. I have seen it where they fail and blow up like a balloon when the pedal is pushed down.
tommi_e21
Re: Brake problem
Post by tommi_e21 »
give them a good bleed, i am sure that will solve the problem.
Audi 50 RS
Tims
Re: Brake problem
Post by Tims »
If you can not see any leaks it is most likely one of the rear cylinders as most of the fluid ends up inside the drum
